Export Features based on Unique Value in a Field (date value)
3607
04-07-2011 09:36 PM
ChristopherBlinn
Hello All,
I am trying to figure out a way to select records from a shapefile (a specific date in (m)m/(d)d/yyyy format, (m) and (d) only for double digits) and export the selection to create a new shapefile.  The issue is I have over 400 of these dates, and rather than selecting each one individually, right clicking the layer, exporting the data, wash, rinse repeat, I'd like to figure out a way to do this like an iteration in modelbuilder.
I read over this post: http://forums.arcgis.com/threads/27764-Model-Iterator-for-Date-Ranges
It sounds similar to what I am doing except I only have one field for a date, and I just need to select and extract features with similar dates.  Also, I am a newbie with modelbuilder and I don't really mess with python, so the script in the forum above is like reading a different language.
Any help is appreciated and thank you in advance!
Best,
Chris
ChristopherBlinn
I should add that I am using ArcGIS 10.0 SP1
ChristopherBlinn
Here is the model I have started.  I can't seem to get the SQL correct for it to work.
"DATE_" = Value
I have also tried:
"DATE_" = %Value%
ChristopherBlinn
I fixed the issue, my SQL needed to say:
DATE_ = date '%Value%'
