Error 99999 when trying to execute Erase tool
2164
02-25-2020 03:55 AM
StefanPetrovic
Dear community,
I am using ArcMap for years and haven't ever asked a question on the forum, simple Google quarry was always enough. I have a serious problem, I am getting 99999 error when trying to execute Erase tool (snapshot attached).
I have tried several things: Reduce the size of the dataset, Repair geometry, move the gdb closer to the root, use shorter
path, run as admin, clear temp, copy to a new gdb, turn-off background processing, etc.
Can you give me some advice?
DuncanHornby
MVP Notable Contributor
Whats you data, a screen shot would help! Is it building footprint polygons, locations of unicorns, or a global geology map of the moon?
WilliamCraft
It looks to me like your topology is corrupted or there is a permissions problem.  Try re-granting permissions on the data, and maybe delete or recreate your topology.
