Dumb question - can I write standalone python script to run without arcgis?
15177
31
05-18-2010 11:54 PM
jimparsons
I need to open a raster, thin it, and save it. Can I do that in a script outside of arcgis, or does arcgis need to be running for the script to work? I have it installed on the system, so it would obviously be running on my computer.
Sorry this question is really simple. I don't really understand how to run a script outside of arcgis...or even if it's possible. I'm hoping someone will say yes or no! Thanks
LoganPugh
You should really look into the python logging, its wonderful: http://docs.python.org/library/logging.html
However you need to create a gp friendly logger... heres an example:
Frank I finally got around to trying this and I had to tweak one line to get it to work:
The line:
if type(sys.stdout)) != "<type 'geoprocessing sys.stdout object'>":
I had to strip whitespace from the type check because on my machine at least it adds whitespace after the type for some reason. So the fixed line is:
if str(type(sys.stdout)).strip() != "<type 'geoprocessing sys.stdout object'>":
Thanks for the nifty example!
LucianoCampagnolo
Hi...
I've a problem with standalone scripts running as 'standalone' 🙂
Let me clarify:
- The scripts run smoothly within an ArcSomething session, be it from Python window or a Script tool added to some toolbox.
- When fired from console (in fact: another program calls it after another non-gis process) or Eclipse or IDLE or anything non-ArcSomething; the execution fails with a "Parameters are not valid" - "ERROR 000824: The tool is not licensed" error.
- The code has the appropriate import arcinfo and arcpy.CheckOutExtension statements.
Running ArcGIS 'for' Desktop (:P) 10 fully patched.
Any help will be appreciated and will post a sum or solution upon successful outcome...
Cheers!
DannyLackey
I wrote a simple script in arcGis and I'm trying to call it without arcgis open.  My plan is to put this in task scheduler to automatically create a PDF.  The script works great within ArcGIS, just not sure how to create an external file to call it (something I can load into windows task scheduler.  My .py file is "PDF_Export_SAPT.py" and the script within it is:
mxd=arcpy.mapping.MapDocument("CURRENT")
arcpy.RefreshActiveView();arcpy.RefreshTOC()
arcpy.mapping.ExportToPDF (mxd,"I:\GIS_Workspace\Ventura_Area\Danny\SAPT_MAP.pdf")
I read in this forum that I can call it from a cmd prompt, which I tried, but got a a syntax error.  I just typed in the name of my .py file and hit enter.  I don't know which (if any) parameters to use.  Here is a screen of error:
[ATTACH=CONFIG]11097[/ATTACH]
Sorry to hijack thread - but I'm so close.  Not sure what type of file I need to create to call this script.  Batch?  thx!
JasonScheirer
Esri Alum
You can't use CURRENT outside of ArcMap.
BruceNielsen
Try changing "CURRENT" to the full path name of your .mxd file. CURRENT only works when you are in ArcMap.
DannyLackey
Well, that eliminated the error, but now NOTHING happens.  Doesn't produce a .pdf.  Was I calling it from command prompt correctly?
Current code:
mxd=arcpy.mapping.MapDocument("I:\GIS_Workspace\Ventura_Area\Danny\SAPTList.mxd") arcpy.RefreshActiveView();arcpy.RefreshTOC() arcpy.mapping.ExportToPDF (mxd,"I:\GIS_Workspace\Ventura_Area\Danny\SAPT_MAP.pdf")
I even tried placing the .py file inside the python directory and calling it like "python PDF_Export_SAPT.py" (without quotes), still nothing.
DannyLackey
Ok, tried running it in python shell and got this error:
File "<pyshell#2>", line 1, in <module>
NameError: name 'arcpy' is not defined>>>
Again, this SAME script run beautifully in ArcGIS.
JasonScheirer
Esri Alum
import arcpy first.
DannyLackey
Tried
import arcpy.mapping
Tried in python shell
got this error:
File "<pyshell#0>", line 1, in <module>
ImportError: No module named arcpy.mapping
Forgive me... Fairly new to ArcGIS...and python.. What would that line of code look like?
DannyLackey
Ok, I got it with import arcpy.  Works great.  However, its panning the map all of the way out so the .pdf file is about 24mb.  Now I need to research the code to change scale/focus area.  thank you!!!
