Decreasing space in C drive while running arctool
1586
03-14-2017 05:24 AM
mohannainar1
While running arctool (example: "create fishnet") it takes some memory from "C" drive ? . I changed "TEMP" and "TMP" environment variable to point D:\temp , even though it is taking space in C drive . Is there any way to avoid this ?
Tags (1)
NeilAyres
It is probably that your default geodatabase is still pointing to your user space on c:
Working with the Home folder and default geodatabase—Help | ArcGIS Desktop
mohannainar1
Hi actually I am running "Create fishnet" arctool . Input file(layer from FGDB) is coming from "D" drive and out I am storing it is D drive file database.  No where I am using default geodatabase.
mohannainar1
I am running the tool from arccatalog.
