creating links/spatial network from points (Military Analyst)
1112
08-05-2010 10:34 AM
SusanWinchell-Sweeney
I've downloaded and used (for the first time) Military Analyst to assist in analyzing an historical (19th-century) resistance movement in Ireland, and specifically the link tool set to create links or spatial networks of resistant movement leaders. It seems like an appropriate use of the extension, but I am looking for "real-world" military examples (or other applications) using the link tool set for a comparison.
Would greatly appreciate any advice and/or assistance - thank you!
Susan W-S
[email protected]
[email protected]
MattFunk
Susan,
Your project is a perfectly acceptable use for the link tools in Military Analyst. Keep in mind that these tools are extremely simple. Too simple in fact, and we are working on a more complete solution for a future ArcGIS.
Anyway, our test case for these tools involve a simple point features of cities around the world (acting as nodes) and a small table of travel routes connecting FROMCITY and TOCITY. The Create Links tool simple connects the city features using the table. The result is a set of line features that visually connect the cities. The Recalculate Links tools will update an existing set of lines (resets the connected cities if travel routes change). The Shortest Path & Critical Links tool takes the node/link network and finds the 'shortest path' between cities and finds any terminal paths (paths endpoint cities that have only one connecting link). Hope this is useful to you.
Matt
