Creating defined lists
2342
11-07-2016 12:00 PM
KevinWyckoff2
I want to create a script that will help me sort a feature class of 7000 features into blocks of 60 features. The features would stay in the same feature class, just have a value added to a field delineating the different groups. I understand what needs to be done, but am completely stumped on where to start looking for help.
Tags (3)
JoshuaBixby
MVP Esteemed Contributor
How do you want the groups defined or grouped together?  For example, do you want OIDs 1-60 to be Group 1/A, OIDs 61-120 to be Group 2/B, etc...  Or, is there some other grouping you want to implement?
JoshuaBixby
If you just want to group the first 60 items into group 1, the second 60 items into group 2, the third 60 items into group 3, etc... then the following should work:
fc =       # path to feature class
block_id = # name of field to populate block id/code
with arcpy.da.UpdateCursor(fc,
                           block_id,
                           sql_clause(None, "ORDER BY ObjectID") as cur:
    for i, _ in enumerate(cur):
        cur.updateRow([i//60 + 1])‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
So you want to produce a uniform distribution of group numbers to which to assign each feature?  If so, then look at the following demonstration of using the random.uniform distribution
>>> z = np.random.randint(1,7, 60000)
>>> bins = np.arange(1,8)
>>> h = np.histogram(z, bins)
>>> h
(array([10046, 10078,  9922,  9936, 10094,  9924]), array([1, 2, 3, 4, 5, 6, 7]))
so the result of the above is 6 groups numbered 1 to 6 inclusive with about 10,000 in each group.
If you need exactly the same number in each group, then that can be done, by producing a range of numbers, repeating it, then shuffling it... for example
PS, I should add that you could produce a table with the results of either and simply join it to the source table or in the case of randint, you can do that in the field calculator... random.shuffle will require a join since the distribution needs to be produced first.  The table case, requires an ID field and the values, to facilitate the join.
>>> vals = np.arange(1,7)
>>> z = np.repeat(vals,10000)
>>> np.random.shuffle(z)
>>> z[:60]
array([1, 5, 4, 1, 6, 6, 3, 3, 4, 2, 1, 3, 1, 6, 3, 6, 1, 6, 3, 6, 3, 4, 5, 1,
       1, 1, 2, 1, 3, 4, 4, 5, 4, 2, 4, 2, 6, 3, 4, 6, 3, 6, 6, 1, 6, 5, 3, 4,
       2, 6, 6, 3, 2, 3, 1, 3, 5, 6, 2, 4])
>>> h = np.histogram(z, np.arange(1,8))
>>> h
(array([10000, 10000, 10000, 10000, 10000, 10000]), array([1, 2, 3, 4, 5, 6, 7]))
Of course you can produce the array then export it to a table using
NumPyArrayToTable—Help | ArcGIS for Desktop
A sample of the prodecure to produce 70 numbers each with a frequency of 10, shuffled so they are in random order...
>>> import numpy as np
>>> z = np.repeat(vals,10)
>>> ID = np.arange(70)
>>> tbl = np.array(list(zip(ID,z)), dtype = [('ID', 'int'), ('Class', 'int')])
>>> tbl
array([(0, 4), (1, 1), (2, 3), (3, 2), (4, 6), (5, 6), (6, 5), (7, 2), (8, 6),
       (9, 6), (10, 3), (11, 3), (12, 1), (13, 5), (14, 2), (15, 6), (16, 5),
       (17, 3), (18, 6), (19, 2), (20, 4), (21, 5), (22, 2), (23, 2), (24, 3),
       (25, 1), (26, 1), (27, 2), (28, 2), (29, 1), (30, 5), (31, 6), (32, 4),
       (33, 5), (34, 3), (35, 4), (36, 4), (37, 1), (38, 4), (39, 4), (40, 6),
       (41, 5), (42, 3), (43, 3), (44, 6), (45, 1), (46, 5), (47, 2), (48, 3),
       (49, 1), (50, 5), (51, 6), (52, 2), (53, 3), (54, 1), (55, 4), (56, 4),
       (57, 5), (58, 4), (59, 1)],
      dtype=[('ID', '<i8'), ('Class', '<i8')])
>>> #then use NumPyArrayToTable to get your table
Then you can save it as a table and join the ID field to the FID or OBJECTID field as appropriate
