Correct steps in using Spatial Autocorrelation (Moran's I)
4928
05-30-2010 07:31 PM
Jessicasy
Hi everyone,
I have a set of point data about palm disease, but I have no idea on how to use the Spatial Autocorrelation tools. The results that have been generated are not really corect. can anyone tell me the proper steps to generate it?
Thank you so much.
Regards,
Jessica
AndrewChapkowski
Hey Jessica,
Here are some resources to help you out:
1). http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=2150&pid=2146&topicname=Spatial_Autocorrelati...)
2). http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=How Spatial Autocorrelation: Moran's I (Spatial Statistics) works
The tool is used to show clustering, and returns a value between +1 and -1.  A value closer to +1 means clustering, while a feature that has a Moran's value closer to -1 means it's dispersed compared to the other surrounding data.
There are many factors that influence your results, like distance bands, threshold distances, the spatial relationship, etc... you need to determine which method is best for your dataset.
If you want to examine clustering with counts, ex: we have 3 trees that infected in the area, you might want to look at the other analysis tools:
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=An_overview_of_the_Mapping_Clusters_to...
Also I would take some time and do this tutorial:
http://resources.esri.com/geoprocessing/index.cfm?fa=codeGalleryDetails&scriptID=16427
and watch these videos:
http://www.youtube.com/esritv#p/u/7/cXXry6wE86M
http://www.youtube.com/esritv#p/u/9/QJtPmnFgZbs
http://www.youtube.com/esritv#p/u/8/3WtpYnlpKaU
Enjoy
A
JeffreyEvans
It is very difficult to provide advise on a field as diverse as spatial statistics without any context to the underlying question. When posting, more information is always better. It is not clear on why you think that the results are not correct. Morans-I and Gearys-C provide an indication of 1st order (global) spatial relationships and result in a single coefficient. Morans-I is the most common 1st order statistic and the one available in ArcMap. As mentioned in the previous post it should range from -1 to 1. Where 0 is indicative of a random spatial process, values ranging towards 1 demonstrate uniform clustering and approach perfect correlation between observations, and -1 is representative of spatial diffusion/repulsion. Geary's-C is a very nice and interpretable statistic. It ranges 0-1 and is, in essence, a global semivariogram. Geary's-C is not as sensitive to the specification of the neighbor matrix and as such can be a much more stable statistic than Moran's-I. However, it does not indicate diffusion/repulsion process if present in the data.
I have a feeling that you are more interested in the 2nd order spatial variation (local autocorrelation). I would highly recommend investigating point pattern statistics. There are a very large array of these statistics but some useful ones are available in ArcMap. In the "Mapping Clusters" toolbox  look at the Getis-Ord (Gi*) and LISA (local Moran's-I) statistics. These are indicative of local autocorrelation/nonstationarity and are probably going to be more informative. You will need to investigate the influence of bandwidth and specification of the spatial weights matrix. Please note that significance testing is a critical step in all of these statistics. The one thing to be mindful of is that; if you observe high 2nd order variation it most likely indicating a spatial dependency (external variable(s) influencing the autocovariance). If this is the case it necessitates models such as Conditional Autoregressive models (CAR), Spatial Autoregressive models (SAR), mixed models and geographically weighted regression (GWR) (available in ArcMap). Bayesian hierarchical models and nonparametric approaches such as spline regression or multivariate adaptive regression splines can be most useful as well.
