Context Usage Timout Interval for Geoprocessing Server
3631
02-28-2011 12:41 PM
KarenRobine
Does anyone know what the Context usage Timeout Interval is in ArcGIS Server Geoprocessing Server?
I'm getting the following errors when I run my model in ArcGIS Server (it runs for like an hour and then blows up):
The context has been automatically released because the Context Usage Timeout Interval has elapsed.
Then, right afterwards, I get
Execution of job <xyz> failed because of crash or termination of the server object.
KarenRobine
This occurs because "The maximum time a client can use a service" set in the Geoprocessing Service Properties wasn't set high enough. The problem is fixed.
AntonioNogueira
Hi:
How has it been fixed? I'm running ArcServer 10 on linux and I'm having the same problem, do I need to install a Service Pack or do I need to increase the timeout interval on my system? is so how/where is the timeout interval set (config file)?
Thanks
MichaelFaulcon
Any updates?
markrobey
Change the 'max time a client can use a service' (right click the
service, select Service Properties, select the pooling tab) to a
suitable number of sceonds.
Mark
