Can I determine the resultant surface based on volumeric change using 3D analyst?
949
04-19-2010 11:26 AM
YanhuiFang
The Cut/Fill tool in 3D analyst allows us to create a map based on two input surfaces - before and after - displaying the gain or loss of the areas and volumes of surface materials.
But how do I determine the "after" surface if I know the "before" surface and the amount of gain?
For example, I know the original water surface level of a lake, and the sediment volume that is filled into the lake within a year. Can I use any 3D analyst tool to determine and visually present the raised water surface level due to the sediment increase?
I have tried "TIN polygon volume", but it doesn't provide the exact function that I need.
I appreciate your help. Thanks!
Yanhui
