Calculate Grid convergence error
1100
01-31-2011 04:45 AM
MichaelStjernholm
Hi
I'm doingh some solar angle calculations and want to include a correction for the difference in angle between the coordinate system I use and the true north.
The tool CalculateGridConvergenceAngle_carthography should be able to do this but I constantly get an error indicating that the field Type should be wrong! (ERROR 000308: Invalid field type)
I have python statements like:
(footprintFC is a layer !)
if len(arcpy.ListFields(FootprintFC, "GeoAngle")) == 0:
    arcpy.AddField_management(FootprintFC, "GeoAngle", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
and
arcpy.CalculateGridConvergenceAngle_cartography(FootprintFC,"GeoAngle","GEOGRAPHIC")
Can somebody help me identifying the problem ?
Michael
DuncanHornby
MVP Notable Contributor
Michael,
If your dataset is a shapefile try setting this:
to
arcpy.AddField_management(FootprintFC, "GeoAngle", "DOUBLE", "", "", "", "", "", "", "")
Duncan
MichaelStjernholm
Hi Duncan
Thanks for your proposal.
I may have found the problem to be that the feature class was joined to a table. Now that I remove the join before CalculateGridAngle I no longer get the error message, which anyhow seemed to be misleading 😞
regards
Michael
