Buffering over a certain distance
1096
02-01-2011 05:22 PM
IrshadJamal
Dear GISers,
I am trying to figure out how to buffer a feature (River) by certain intervals, (0-50m, 50-100m, 100-250m, 250-500m and greater than 500m)
I am able to use the multiple ring buffer tool in ArcGIS 9.3 to buffer the first 4 criteria, but how do I handle a distance greater than 500m?
Thanks very much.
jamali
DanPatterson_Retired
did you rule out putting in a value that you know would extend beyond the extents of your input layer?...then clip to your extents to limit the excess?
IrshadJamal
Hi Dan,
Thanks for your kind response. I do have about 13 different input layers that belong to a study area. The objective of the exercise is to assign criteria scores (1-100) depending on distance from the themes.
I guess I could find out the theme with the greatest extent and use that value as a basis for the other themes and then clip out the excess.
Warm regards,
Irshad
