Batch clipping annotation unexpected results
947
02-24-2010 10:21 AM
MarkJohnson
I needed to clip several annotation layers so I used the Batch option on the Analysis -> Clip tool to build a task clipping 3 annotation layers.  Everything seemed to run fine, except the resulting layers display nothing in ArcMap.  There are features in the attribute table that appear the same as the original layer but nothing draws.
I went back and individually clipped the layers and the Clip1 layers display as expected.  I don't know if there's a bug in the batch part or if I messed it up somewhere, I've been successfully batch clipping "regular" layers all morning.
NatalieMatthews
I tried out your workflow using the Pre-release version of the software but was unable to reproduce the problem.  Please try this again once the Pre-release version is available and contact Support if you continue to experience this issue.
Natalie
