Backing Up Files Using Model Builder
7447
13
06-15-2012 08:22 AM
by Anonymous User
Not applicable
Original User: MCline19
I am trying to create a model, using model builder, that will back up multiple files under certain conditions.  The files being backed up are .sde files and I need them to be backed up as .shp files.  I am using the "Feature Class To Shapefile (multiple)" conversion tool to accomplish this.
The conditions I need to meet include:
1. Keeps current file names
2. Overwrites existing files
3. Only backup files which have been modified since the previous backup
Currently, using the "Feature Class to Shapefile (multiple)" conversion tool, I have been able to meet my first two conditions; however I have not been able to figure out how to satisfy my third condition or if their is a tool capable of doing this.
I would appreciate any advise on how to solve this issue.
THANKS!
Marie
by Anonymous User
Not applicable
UPDATE:
I was able to get the precondition set and the connection has been made between Compare Status and Calculate Value.  Additional to your suggestions, I had to right click on the Calculate Value tool, go to Properties, click the Precondition tab, and check the box next to Compare Status.
However, I am still getting an error with regard to my syntax.  Any suggestions would be appreciated.
ShitijMehta
Hi MCline19,
Check the attached image. Hope this helps. Write back if this does not work.
by Anonymous User
Not applicable
Shitij,
I was able to make a lot of progress with your last post.  Thank you!  However, there still seems to be something wrong with the code block.  It returns an error.
I have attached an image of the model, the calculate value if-then code block, and the error message I receive when running the entire model.
The error states 'true' is not defined.  I also ran the model using 2 files I knew to be different, which returned the same error stating 'false' is not defined.
I apprecaite your help.
ShitijMehta
Hi MCline19,
Try this:
Put quotes around the x("%CompareStatus%") in the expression of the Calculate Value tool. Does that work?
