Automatically adjust line to polygon edge when within a set distance
1584
09-14-2020 05:24 AM
LanceCole
I have a line feature that is suppose to be coincident with the edge of a polygon feature.  At about 600 locations, the line is not coincident and I am looking for a automatic method to adjust the line, without modifying the polygon feature, if the line falls within a given distance, say 5 feet.  I have tried the Snap (Editing)—ArcMap | Documentation tool and the Integrate (Data Management)—ArcMap | Documentation tool. However, because of the large tolerance needed, results in the polygon being modified even when setting a large difference in the features rankings.  I also added the layers to a feature dateset with topology.  This did identify all the errors, however, I cannot fine a way to correct the issues except individually.
In the photo below, the red line should be coincident with the polygons edges.  Off by less than 1 ft at this location.
Line Error
Any suggestions.  Currently using ArcGIS Desktop 10.8.1.  I know I have fixed this type of error previously but cannot recall how.
DanPatterson
MVP Esteemed Contributor
Lance Cole‌ from the Integrate help, you ruled out the suggestions in the Topology link?
Topology basics—ArcMap | Documentation
... sort of retired...
