ArcGIS Server not executing GP Tool that uses an aprx and map series
820
08-15-2024 09:18 AM
gorozcos
Hi GIS Community,
I developed a Python Geoprocessing tool that creates field sheets on the fly through a Web AppBuilder or Experience Builder.
The tool was working with mxd projects, however now with ArcMap out of the picture I updated my Python code to work with Pro. The tool works well and generates field sheets inside Pro with Map Series (the Python code is fine). Then, I published the GPTool to an ArcGIS Server and from the rest point executed the tool but it is not working,; it just keep trying to access the aprx project and finally fails because of long time execution.
I already checked the compatibility between the ArcGIS Server 11.1 and the Pro version 3.1.0.
Anybody has any solution?
I will appreciate any help, thank you!
