ArcGIS 10 SP4 Spatial Join Bug
13354
26
04-04-2012 12:57 AM
BenHolmes
Hi
Just to let you know I've experienced the spatial join bug found in SP4.
I was joining 740000+ points to 13 polygons
Just under 19000 records had attribute data come across. The rest were all null.
I've run the exact same data on another machine with ArcGIS 10 SP3 and it worked fine.
I see there was a bug listed ( NIM079126 ) but for some reason it's been declined. Not sure why this is, but you should know this is happening to others.
One thing I noticed was the last record to have an entry before the attributes failed to populate was a point that was outside all polygons I was trying to join to. I'd suggest creating a point dataset with one point outisde the main body of a join polygon to test this. Maybe then we can see some work towards a solution.
Ben
DanLee
by Esri Regular Contributor
Planned for July, 2012.
MikeLouwrens
I too have struck this bug, and unfortunately using "Keep All Target Features" doesn't work for me as I still need the points to be present, even if they don't spatially join.  I am now attempting to uninstall SP4 just so I can run my model.
Mike.
MikeLouwrens
First: we are working hard on a special patch on 10 SP4 to fix the problems. Hope it will come out soon.
Can you confirm there will be a targetted patch pre-SP5?  Any idea on due-date?
Cheers,
Mike.
JamesMcCarty
I wanted to let you know that this toolbox did the trick.  I was also having the same problem with points that did not intersect with a polygon would not transfer their attributes.
The attached Toolbox contains a model that may be helpful in working around this issue until the bug is resolved. It has proved helpful for some customers.
NobbirAhmed
Esri Alum
Please check out my response in this thread:
http://forums.arcgis.com/threads/39018-Model-Builder-ArcGIS-crash-using-Spatial-Join-in-a-model
The issue is fixed and a patch is being prepared for general delivery.
DanMcCoy
Cheers,
Mike.
"A patch is planned to be released around the end of April/early May 2012 that resolves this defect."
http://support.esri.com/en/knowledgebase/techarticles/detail/40174
NobbirAhmed
Esri Alum
The following Spatial Join patch fixing the issue is now available on resource center through this link:
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=160&MetaID=1857
