ArcGIS 10: Reclassify by Table problem
2061
09-16-2010 05:31 PM
SoniaHugh
Hello Everyone,
I'm trying to do a simple reclassification of a grid.  I followed the same steps as I would if working with ArcGIS 9.3.  Create a table with From, To and Out columns.  Open the 'Reclass by Table' tool and it recognises all of the inputs.  Once I okay it and it processes I get the following error 'Error 999998: An attempt was made to reference a token that does not exist,"  and once the screen refreshes each one of my layers has a dimmed out check box with a red exclamation mark next to it (as if it doesn't recognise the source data).
I'm not sure what is going on here. Is it to do with the new Arc 10 installation and not correctly removing Arc 9.3?  I'm also having problems with the Field Calculator and joining tables but I'll leave that for another forum question.
Your help is much appreciated.
