ArcGIS 10 Batch Clip
3355
08-22-2015 12:47 PM
RyanChittenden
Hi, I was wondering if you still had the clip workspace tool, and where I can still get it.  The link provided no longer works.
A little background...
I work for CAL FIRE making maps of wildland fire incidents.  My external hard drive has state wide data and I need to be able to clip the state wide data to the specific area around the fire.  This tool would help immensely.
Ryan Chittenden
XanderBakker
Esri Esteemed Contributor
If you search for "Workspace clip" in Search ArcScripts (BETA) you will find two tools:
http://www.arcgis.com/home/item.html?id=2b3717276cea447889b0a10dcbe5a580 and
http://www.arcgis.com/home/item.html?id=f15fe0b461a44d25aa02cfbce633b453
Give it a try. If it doesn't work I can provide you with some Python code to do this.
Kind regards, Xander
