Apparent Reflectance Errors
813
11-07-2024 02:30 PM
songosmond
I'm interested in calculating albedo values from a Landsat image layer. I'm currently using this Multispectral Landsat layer with raster data from Esri, and the apparent reflectance function in ArcGIS Online to create a new layer with albedo values.
My specific focus area is average albedo value at a census tract level within Richmond, California. To make the data processing more manageable, I've clipped the raster data / landsat layer to Richmond, CA.
When performing the Apparent Reflectance function, I switch the output value to "albedo", and I don't input any corrective values for Radiance Gain, Radiance Bias, Reflective Gain, nor Reflective Bias. For Scale Factor and Offset, I entered "0" as the help button indicated is fitting when the desired output value is albedo.
However, whenever I try and actually run the function, I always receive an error message that reads "Submission failed. Failed to execute EstimateRasterAnalysisCost". I initially thought that the layer for Landsat was too big [as it covers the whole globe] and therefore it was too much data. I then cropped it to just Richmond and its surrounds and the same error message was still generated.
Does anyone have any suggestions on why this keeps failing? Any advice or suggestions would be super appreciated. Thanks!
