A tool to delete identical points,
1457
07-22-2014 03:40 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out if there is a tool to delete identical points. For example, in the screenshot below, we got 3 identical points at the same location. What I need is to delete 2 of them to keep just one at that position.
What tool might do this sort of thing?
Thank you
Best
Jamal
Jamal Numan
AsrujitSengupta
It does, have a look at the web help documents:
Let me know if I am mis-understanding anything!
AsrujitSengupta
Have a look at the below tools:
  • Find Identical (Data Management)
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
  • Delete Identical (Data Management)
JamalNUMAN
These two tools don’t have the power to delete the duplicates of points!
Jamal Numan
AsrujitSengupta
JamalNUMAN
Thanks Asrujit. Perfect. The issue is resolved
The “feature vertices to points” tool creates 12,870 points considering the “both ends” option. Now with the “delete identical” tool (shape is selected) the points are reduced to 5,394.
This way, we have one single point at each point of intersection of lines
Jamal Numan
