10.3 geocoders not working
3816
02-24-2015 11:00 AM
winstonmckenna1
I recently upgraded, desktop, server, engine and SDE to 10.3, and of course had to upgrade some other features and extensions. It seems that now that I've upgraded to 10.3 my new 10.3 geocoders will not find or identify addresses. Strangely, when using the Address Inspector on the Geocoding Tool bar it will identify address with the 10.3 GC, but won't find any when using the search bar. Has anyone had any similar issues? If I'm missing something, somewhere I'd appreciate some insight. Thanks
ShanaBritt
Winston:
It's possible that you are running into the issue described in the following article.
Bug: Dual Ranges address locators created with ArcGIS for Desktop 10.1 and higher do not return matc...
-Shana
JoeBorgione
That's where my money is too.
That should just about do it....
MichaelVolz
Esteemed Contributor
What address locator style are you using?
JoeBorgione
I'm at 10.5; op is having the issue...
