What SQL version för ArcGIS PRO 2.7?
2066
02-18-2021 10:54 AM
SwerefTM
Is there a compability matrix to understand what SQL version I need to install If I work with ArcGIS pro?
My knowledge in installing servers is not the best. This is just a workshop for me to understand
how a server has to be setup to work with ArcGIS pro. For this workshop I will not install all the enterprise package. I just want to learn how to install and setup the server correct.
What I want accomplish is this.
Install a SQL server correct to be able to work with ArcGIS pro  and FME to read and write to SDE.
Ive tried the free SQLEXPRESS but I only get it to work with ArcGIS desktop 10.x.
What I ment by work is referring to
* create .sde
* create featureclasses with ArcCatalog and ArcGIS desktop
What I did not manage to work
Creating a database connection (sde)  in ArcGIS PRO
What I have installed
SQL express the latest version
SQL Management studio
Microsoft_ODBC_Driver_17 for SQL server
Summarize
Novice skilled in databas servers
I just want to learn how to install and setup the server correct so I can work seamless with FME and PRO.
by Anonymous User
Not applicable
Here is info on the compatibility between ArcGIS Pro and SQL Server versions:
Microsoft SQL Server database requirements for ArcGIS 10.8.x and ArcGIS Pro 2.5, 2.6, and 2.7
by Anonymous User
Not applicable
SwerefTM
Thanks.. I will read the documentaion and try do install the clients accordning to the informationen on that page.
I will update this thread if I succeeded.
