Versioning Question
3971
7
01-24-2017 12:43 PM
DEAF_PROBERT_68
Honored Contributor
I am aware that ESRI has put up Versioning on their ArcGIS help online but is there that has PDF ?
What is a version?—ArcGIS Help | ArcGIS for Desktop
But I'd like to get some tips from you that might be helpful to me. My supervisor wrote down the steps on how to do it. I want to understand it better and how it works.
They can be tutorial, brochure, video, etc...For the video, I'd like to have either subtitles or Closed-captioned.
Ahmed_AltafTambe
Asrujit_SenGupta
One of the best explanations in brief I came across was in this link: Versioning 101
PDF: http://www.esri.com/news/arcuser/0110/files/versioning101.pdf
I'll suggest going through all the ArcGIS Help resource for a sound understanding of the Topic: An overview of versioning—ArcGIS Help | ArcGIS for Desktop
RebeccaStrauch__GISP
I find the resource lists of links they publish for some of the classes are always good.  This one is for
https://community.esri.com/docs/DOC-2803
Which talks about geodatabases and there is a section on versioning.
DEAF_PROBERT_68
Honored Contributor
That is a very good resource to have ! Thank you. I will take a look at that you posted it.
DerekLaw
Esri Esteemed Contributor
Hi Robert,
There are a couple of older Esri whitepapers on the topic available as well:
Hope this helps,
Robert_LeClair
There is a Implementing Versioned Workflows in a Multiuser Geodatabase Instructor Led class that may benefit you as well.
And the class resource for that
Implementing Versioned Workflows in a Multiuser Geodatabase (10.4) Course Resources
RE are actually resource lists for many of the classes....look at the documents in this training space to see others.
