I'm getting this type of error when try to Enable Enterprise Geodatabase:
Underlying DBMS errorFail to enable database option ALLOW_SNAPSHOT_ISOLATION and READ_COMMITTED_SNAPSHOT.
Failed to execute (EnableEnterpriseGeodatabase).
But both option:
- Allow Snapshot Issolation
- Is Read Committed Shanpshot On
are set to True.
What else can be wrong?
I dont have a "-" and I get get this error !
Observed the same issue with the Database name with DOT ".", Once I replace the database name with "_" GP tool is working fine and enterprise Geodatabase created and configured.
I have observed the same issue with Database Name, Once the DB name is removed with the "-" GP tool works fine.
ALTER DATABASE "DB_Name" SET READ_COMMITTED_SNAPSHOT ON;
ALTER DATABASE "DB_Name" SET ALLOW_SNAPSHOT_ISOLATION ON ;
With new name
