Unchecked "Geodatabase is accepting connections"
2724
03-14-2018 11:49 PM
MahizharasanSrinivasan1
What cause frequently "Geodatabase is accepting connections" getting unchecked in ArcCatalog 10.1 Database Properties??
Asrujit_SenGupta
For sure, it should not be happening on its own. Do you have any script which may be doing this before executing some other administrative tasks?
AcceptConnections—ArcPy Functions | ArcGIS Desktop
Scripts are there, but same scripts are not creating any issues on other machines. I mean to say after script completion on other system "Geodatabase is accepting connections" is checked. Only to a particular system it is Unchecked.
Asrujit_SenGupta
This doesn't concern systems. It depends on what is being done using these Python Scripts and which Geodatabase is that pointing to in the script.
I can execute a Script on Server-A, which will modify Geodatabase that is on Server-B. So this is possible.
My suggestion, is to go through all the Scripts, in which this particular Enterprise geodatabase is referenced and check if any of them, is scripted to stop Accepting Connection for that particular gdb.
