synchronize replica changes is hanging
489
08-09-2022 01:37 AM
DasheEbra
Occasional Contributor II
Dears, I work with ArcGIS Pro 2.9 to create a Check Out/In gdb replica, a replica with Check_Non_File name has created and edits has done, then the synchronize changes tool run on this replica. Therefore I created a new replica with Check_Non_File2 name, every thing is ok unless the synchronize changes tool the Replica parameter is hanging and the drop down menu for this parameter only shows the previous replica (Check_Non_File) which is already sync and deleted. So to be able to solve this I have to re-open ArcGIS Pro which is not a logic solution.
MarlonAmaya
Hi El_Saket,
What happens if refresh the database connection? Do we see the new replica that was created?
