SAP HANA schema visibility (strange chars)
912
07-21-2017 12:09 AM
DamianoMorosi1
Hi everyone,
I'm trying to visualize in the Catalog of ArcMap some tables hosted by a SAP HANA instance. The full name (schema + table name) of the tables is something like this:
SCHEMA_NAME.TableName
or
SCHEMA_NAME::DM.TableName
I'm not an expert in HANA but the people working on it are saying that the ::DM part of the schema is a suffix for Data Model. However, the first kind of schema.table is showed correctly in the Catalog, while the one with the ::DM part isn't viewable.
By the way, if I create a Query Layer by adding it directly (File -> Add Data -> Add Query Layer) and I write something like "select * from SCHEMA_NAME::DM.TableName" it works, so it only seems a problem of visibility in the Catalog.
Have you ever experienced something like this? I'm using ArcGIS 10.3.1 and the version of the SAP HANA ODBC driver is 1.00.120.042.1474657934
Tags (3)
