Repair Data Source - New Data Location
3690
6
02-07-2018 12:26 PM
by Anonymous User
Not applicable
I'm migrating my data to a new server and I have 1000's of MXD's which will have broken layers due to the new location of the data.
Is there a method of sourcing all these MXD's to the new data location from multiple machines using single-use licenses?
I've come across this thread a couple times with no clear answer form what I could see.
Thanks
TinaMorgan1
You can use python to script the resourcing of all your map documents.
Updating and fixing data sources with arcpy.mapping—Help | ArcGIS for Desktop
A simple example would be...
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\ResourceMe.mxd")
for lyr in arcpy.mapping.ListLayers(mxd):
    if lyr.isRasterLayer:
        print lyr.dataSource
        wsp = lyr.workspacePath
        ds = lyr.datasetName
        lyr.replaceDataSource(r"C:\Users\userprofile\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\DirectConnect.sde", "SDE_WORKSPACE", ds, False)
        lyr.name = ds
    else:
        mxd.findAndReplaceWorkspacePaths(r"C:\Users\userprofile\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\AppSvr10.sde",r"C:\Users\userprofile\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\DirectConnect.sde", False)
mxd.saveACopy(r"C:\ResourceMe1.mxd")
del mxd
print complete
JayantaPoddar
Just thought you could use Syntax Highlighter while writing a script here.
Think Location
TinaMorgan1
That just made my life so much better, and it is Friday!
by Anonymous User
Not applicable
I've downloaded your add-in and every step works great until step 5.
I get the following error message:
I'm currently running 10.6 and here is a snippet of my "UpdateToNewDrive.csv"
RebeccaStrauch__GISP
I haven't tested on 10.6, so that might be the issue.  But you can try to unzip the .addin and go directly to the toolbox.  Right-click on the tool and Source.  See if it can find the .py script for the tool.  You may need to go up a folder to find the scripts folder.
I know I have had some issues with 10.5.1 with the "store relative path" for the script doing some weird stuff (trying to look on the "C$" share) when upgrading to newer version.  It was developed mainly on 10.2.x.
The only other thing might be if you have spaces in the path names.  I can't remember if I handle things for that.
