relationship class rule not working
537
05-05-2025 04:22 PM
PierreloupDucroix
I have a feature class containing subtypes in a dataset (from a Utility network) and another feature class without subtypes in another dataset.
I added a relationship class between both FS, and it is working.
Now I want to restrict relationship with rules, so that I can add relations only for some subtypes.
I added relationship class rules so that only one subtype (HTA câble) can have relation with MT_PROFE feature class :
However, once I use the feature service, I can still add an MT_PROF in relation with other subtypes
Here you can see a subtype "BT Câble" in relation with an MT_PROFE, which is not allowed :
I tried to restart and even republish web service.
Any idea ?
CEO of MAGIS
PierreloupDucroix
I tried in a local version of my geodatabase and it works well.
After setting up relationship rules, I get an error message :
feature MT_PROFE cannot be related to ElectricLine subtype BT câble because there is no relationship rule
I will log a case with Esri support
CEO of MAGIS
RobertKrisher
Does it work if you uncheck the box next to enabled for the subtypes you don't want to be related to the MT_PROFE? Manage relationship class rules topic from the ArcGIS Help says only to check Enable when you want to have a rule that allows them to be related. Removing the rule (by disabling it) should cause other relationships to create errors.
PierreloupDucroix
I tried it, but with the same result. I also tried to remove values for min/max on subtype side.
I did it this way the first time because I saw it in a Utility Network Foundation APRX, but I'm not sure what the best way to configure these rules is.
CEO of MAGIS
PierreloupDucroix
CEO of MAGIS
PierreloupDucroix
FYI : BUG-000176986: Rules enabled on a relationship class are not being honored by the referenced Feature service published to ArcGIS Enterprise
CEO of MAGIS
