I'm not and expert with the geodatabase concept.
I need to register geodatabase tables. So, I will use the "sdetable -o register" and "sdelayer -o register" commands.
In my geodatabase, I have different entity types like simple line(l), point (p), annotation (A) and polygon (????).
When I look at the help of the register command (http://help.arcgis.com/en/geodatabase/10.0/admin_cmds/support_files/datamgmt/sdelayer.htm), I'm not sure with entity type I have to select for the polygon. As I understand, we can have a combinaison of more than one entity type (like -e nac+).
Does anybody know which entiy type I must use for polygon ? Do you know how to determine the right entity type?
Thank's in advance!
Yves
