Precision vs. XY Resolution
2426
8
06-03-2022 03:19 PM
Bud
Legendary Contributor
ArcMap 10.7.1.:
I've created a new point FC from scratch using Catalog (using all the default settings).
The General tab mentions "Storage: High Precision":
Whereas the Domain, Resolution and Tolerance tab mentions "XY Resolution":
What's the difference between "Precision" and "XY Resolution".
Thanks.
by Anonymous User
Not applicable
This article  has helped me several times to understand this.
High precision allows you to store coordinates to incredible detail, and as far as I know is the default. In the long ago past, high precision was not available and old datasets had to be migrated to to high precision storage. These days it is just the normal state of affairs - no changes needed.
DerekLaw
Esri Esteemed Contributor
Hi @Bud,
Back in 2007, I wrote a detailed Esri technical paper that discussed in detail how spatial domains were stored in feature classes in a geodatabase. Please take a look,
Understanding Coordinate Management in the Geodatabase
It might be a little deeper than you wanted to know, but in case you were interested. 🙂
Hope this helps,
by Anonymous User
Not applicable
@DerekLawthank you for this post. The information in your paper is extremely helpful - this is the kind of post that makes the community so valuable.
I see that the paper is dated 2007. Could you please comment what, if any, changes have occurred since then?
VinceAngelo
No real changes to the geodatabase model infrastructure since then.
Note that "precision" refers to both the vertex equivalence comparison tolerance AND the spatial reference coordinate storage depth (though at this point, *all* spatial references are HIGH precision).
- V
DerekLaw
Hi @Anonymous User,
As @VinceAngelo stated, there hasn't been any major changes to the geodatabase data model since the technical paper was published (otherwise, we would have updated it).
Hope this helps,
JTLancer
I'm curious about defaults for State Plane cooordinate system. We are standing up a brand new Enterprise GDB and paying close attention to spatial references as our old database from which we are migrating data through various practices over the years have may inconsistencies.
The screenshot below shows the different srid values by using the Create Feature Dataset tool and different results by by using different settings. For xycluster_tol we get differnet values when accepting defualts with no values specified in environments vs providing these values.
My main question is ESRI articles state 0.003281 would be the correct default value to use. If this rounded number is not pvided the default value ends up being 0.00328083333333333. Does this have an effect if we keep the repeating decimals vs rounding to 6 decimal places.  I'm leaning toward the rounded numbers as a "master" dataset.  The numbers input in the environments affect other things like the xyunits calc.
Also if we leave m and z cluster_tol blank it defaults to .001 in meters rather than feet.  In this case we won't be using m and z, but I imagine as a best practice or potential future use of m or z, that we would want to keep the inital spatial reference properties the same. Any thoughts or input would be appreciated.
 @DerekLaw @VinceAngelo
Understanding Coordinate Management in the Geodatabase  link does not seem to be active any more
@DerekLaw
This article  has been a good resource for me as well.
DerekLaw
Hi @JTLancer,
Thanks for bringing the broken link to my attention. I'll try and get it fixed.
Meanwhile, I've attached a copy of the technical paper to this post. I wrote it back in 2007. 😉
Hope this helps,
VinceAngelo
I'm not a big fan of coordsys offsets with large numbers of significant digits.   0.003281 would be an *awful* precision to use.  I would choose 0.001 or 0.002, since the conversion to integer is "times 1000" or "times 500" (and not "times 304.78512648582749161840902163974". Precision to a thousandth of a foot is gratuitous overkill for all but precision amoeba farming, but it's a nice round number. I try to avoid the default values, because they were chosen to maximize precision, at the cost of compressibility, and I'd rather transfer a BLOB with 278 bytes than one with 40K (your mileage may vary, but you should take your most complex geometries and try them at different scalefactors, to determine what the exact compression loss might be).
- V
