Point layer is no longer displayed but attribute table is still there.
6223
19
02-08-2018 07:22 PM
AlexP_
I have ArcMap 10.5.1.  I had point feature layers display on ArcMap for like a month. But now my point feature layer drawing (SDE) is no longer displayed. It is like disappeared. But my attribute table info is still there. How can restore the drawing point feature layer? Please advise! Thank you!
JayantaPoddar
Looks like the data has got corrupt. I can't think of a way to bring it back, unless you have any working backup data.
Think Location
AlexP_
okay. Thank you for your assist..
George_Thompson
Esri Notable Contributor
Check the spatial index of the feature class. It may need to be rebuilt.
--- George T.
AlexP_
Please confirm if this is the step I should do. I found this link.
Rebuild a spatial index—ArcGIS Help | ArcGIS Desktop
George_Thompson
Sure that should work. Make sure you connect as the data owner in ArcMap. You can also rebuild it via the feature classes connection properties.
--- George T.
AlexP_
Please see screenshot.
George_Thompson
You can do it that way! Just make sure there are no locks on the feature class and you connect as the data owner.
--- George T.
AlexP_
Thank you. Yes. I am the data owner. It is not lock anymore. I am reading the document so I will click recalcuate for SQL.
George_Thompson
Sure thing. You could delete and recreate the index also. That is basically the same thing.
--- George T.
AlexP_
It wasn't success. It is still not display. Also, tried to restore the back up but DBA told me this layer has no record as well. This is so odd.
