Migration of attribute assistant rules
1035
09-05-2025 02:16 PM
Jessica_GISworker
Hi Team,
I have an organizational requirement where I need to move the attribute assistant based rules from one enterprise geodatabase feature to another. Both the data in different geodatabase are identical.
Can someone suggest a easier workflow or automatic ones for conducting the operation
I am using ArcMap 10.81.
Looking forward to your suggestions.
Regards,
Jessica
RhettZufelt
MVP Notable Contributor
Attribute assistant rules run on the layers loaded into the ArcMap project and are controlled by the table named "Dynamic Value".
Not sure of your exact request as you state, 'from one feature to another' and 'data in different geodatabase are identical'
If you are just trying to have the same setup, but pulling data from the 'new' geodatabase and not the old, you would first have to re-source the layers in ArcMap (or create new map with the 'new' layers) to the new geodatabase, you should be able to just connect to the same Dynamic Value table (or, copy it to the new geodatabase also), and the assistant rules should work as before.
R_
