Merging or appending data to existing feature class field
4362
5
05-26-2021 06:29 PM
RomanFox
I hope this is the correct location and a simple question.  I am looking to add or append data to an existing feature class field.  I have an existing feature class that contains an ID field and a "Special" field among others.  I have a standalone table with a ID field and a "Special" field.  The feature class has ~15,000 objects and the standalone table ~1,500.  I would like to use the ID in the stand alone to add the text in the data table's "Special" field to the feature classes "Special" field.  For example in ID 123 is in the standalone table with "existing" in the "Special" field, then I would like the feature class to show "existing" in the Special note for ID 123.
Thoughts?
by Anonymous User
Not applicable
Use Join.
RomanFox
Can this be done without creating a new field?   I have used the Join Field tool.  However, it created a new field.  I would like to have the existing data in the text field remain and the new data from the standalone table added.
by Anonymous User
Not applicable
Use Append.
Raj-Chavada
Agreed that Append GP tool is the right tool for appending new data.
For updating existing records- take a look at this documentation https://desktop.arcgis.com/en/arcmap/latest/manage-data/tables/relating-the-attributes-in-one-table-...
You may able to accomplish this by creating first Relate between FC and Standalone table in map document. Afterwards, you can use select by attribute followed by calculate field.
RomanFox
This has been helpful, I am stuck at the calculate field step with the sql expression.  I am trying to add the "Special" field to the "Appended" field if "Appended" is <NULL>.  Does this seem logical, and if so do you know of a resource for the sql or python expression?
