Map service published from spatial view is not updated when data in the view is changed
1885
09-01-2021 07:33 AM
RoseZhou2
I have a PostgreSQL geodatabase. There are two feature classes with the same schema in it. One stores archived data, another one stores live data and is updated every 15 mins.
I created a spatial view to combine the data from these two feature classes and published map service using the spatial view.
The problem is when one of the feature class gets updated, the map service is not updated, even I restart the map service. The only way to refresh the map service is to re-publish the map service. Does anyone know why the map service is not updated?
Rose
jcarlson
Are you publishing your service with the registered geodatabase connection? It sounds as if it's copying the data to the server rather than maintaining a live connection.
Is your spatial view registered with the database?
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
RoseZhou2
Thanks Josh for your prompt response. You are a life saver!
Yes, the spatial view was registered with the database. The geodatabase was registered before. At one time the geodatabase was renamed. I was not aware of this. I re-registered the geodatabase connection, and everything worked.
Thanks again!
Rose
