Invalid ecp file when updating my enterprise geodatabase
6926
12
10-31-2016 12:13 PM
RandallClark2
I just finished  authorizing my sever licence and went on to update the ArcSDE enterprise geodatabase license, when i try to upload the ECP file that was generated i get the warning that it is an "Invalid authorization file".
Here are the steps i followed
log on to the machine running AGS
Use the Software Authorization tool to authorize my sever using the provsioning file (prvc)
Navigate to the ESRI\License10.4\sysgen folder
copy and rename the keycodes file with the ECP extension
copy the ECP file to my desktop
connect to the database using my established admin connection
upload the ECP
and get the "Invalid authorization file"
i even tried restarting my server.
and here is what is authorized by my prvc file
arcsdeserver
svrenterprise
arcgisserver
schematicssvr
capacitysvr_4
svradvanced
3dserver
spatialserver
networkserver
imageextserver
interopserver
jtxserver
geostatserver
highwayssvr
datareviewersvr
geoeventsvr
portal_50
any
thoughts?
edit one:
When i log on to ArcGIS Sever Manger and check the ArcGIS Software Authorization tab it show the software as not being updated despite being told that it was successful
JayantaPoddar
Are you able to open ArcGIS Server Manager? Then check the license details under
Site > Software Authorization
Think Location
RandallClark2
Interesting.
it says the software has not been updated, Expiration Date is still Oct 29, 2016 so was my authorization file not good?
JayantaPoddar
In that case, rename/delete the keycode file in Esri Folder.
Then authorize ArcGIS Server again by Offline method (Authorize at Esri's Website or by email to receive your authorization file). Use the ECP file to authorize ArcGIS Server and for updating your enterprise GDB.
If the issue persists, you might need to check for valid license keycodes (The keycodes in the PRVC file would have expired.)
Think Location
