How could to change the Tolerance
3391
05-23-2017 12:41 PM
WilsonCalmon
Hi my friends!
Is possible to change the Feature Class Tolerance?
If so, how can I do it?
I want to set 0,01001 m instead of 0,0285714... as below.
ArcGIS 9.3
Licence Type ArcInfo
Thanks for support!
JayantaPoddar
Once a feature class is created, you will not be allowed to change its tolerance/resolution.
What you could do is create a new feature class with desired resolution and tolerance, and import the attribute schema from the old feature class.
Once the feature class is created, then you could just use Append tool to transfer all the records from old feature class to new feature class.
Think Location
JayantaPoddar
What is the version of ArcGIS Desktop?
Think Location
WilsonCalmon
ArcGIS 9.3
JayantaPoddar
Think Location
