Geometric Network Issue
5590
6
12-03-2015 06:23 AM
GastonArias
Hi, we are having a problem with the geometric network in ArcGIS 10.3.
Our infraestructure is based on: Oracle 11g, ArcGIS Enterprise 10.3, everything running over Windows 2008 Standar (x64)
From one day to another, our geometric network broke.
After the geometric network failed, when we tryed to acces to a feature class that is part of that geometric network we got the following message
"Error opening dataset
Network property already exists. [Property name: 'Max Out Degree' in the GISRED.N_5_PROPS table]
The feature class participates in a geometric network that could not be opened."
The Oracle tables called N_#_PROPS, N_#_JDESK, N_#_FLODIR, N_#_ETOPO, N_#_ESTATUS, N_#_EDESK, N_#_DESDK, N_#_JTOPO and N_#_JTOPO2 are empty.
Tags (1)
JoeBorgione
A geometric network isn't a network analysis issue; you should probably repost this in a more appropriate space.
George_Thompson
Esri Notable Contributor
I would also mention the Geodatabase group as you are using Oracle.
--- George T.
GastonArias
George ThompsonWhat are you meaning with "Geodatabase group"?
George_Thompson
use the "@ Mention" function....
Geodatabase
--- George T.
GastonArias
Cynthia Matney​ may you help us with that?
George_Thompson
Gaston - If possible it may be necessary to get a case with Esri Tech Support open to have them help you troubleshoot the issue. Issues with Geometric Networks can be VERY complicated and need to be handled as such.
hope this helps.....
-George
--- George T.
