Geodatabase
6209
8
02-21-2015 08:16 PM
MostafaAtir1
What are best tools for geodatabase design that can be used in ArcGIS modeling projects ?
Mostafa
DanPatterson_Retired
Are you looking for documents to supplement the help files? ArcGIS Help (10.2, 10.2.1, and 10.2.2)
MostafaAtir1
No, I am looking for a tool to Create, edit, ... a geodatabase schema.
OwenEarley
You may want to check out the ArcGIS Diagrammer - Demonstration Video - YouTube
The ArcGIS 10.1 version is available here, but there should be a version of the tool for ArcGIS 10.0 around somewhere as well. ESRI keeps changing the links to older resources
MostafaAtir1
Thank you Owen
OwenEarley
No problem - I haven't used it for a while but ArcGIS Diagrammer was very useful for a project I worked on some time ago.
JayantaPoddar
MVP Alum
Which version of ArcGIS are you using?
Think Location
MostafaAtir1
I am using ArcGIS 10.0
TomBos
You might want to look into X-Ray for ArcGIS - not sure if it works on 10.0 though.
