Geodatabase synchronization between oracle and MS-SQL databases
1881
06-02-2022 02:10 AM
AbhijeetKulkarni
Hi All,
I am trying to build replication between Oracle and MS-SQL geodatabases but I am unable to do so. Has anyone succeeded in building sync system where source and destination are different DB and different versioning  enabled?
Source: Oracle geodatabase (10.4.1)- Traditional versioned
Destination: MS-SQL geodatabase (10.9.1) Branch versioned
Thank You.
AbhijeetKulkarni
Since ESRI replication setup is not recommended for multiple complications as mentioned by Vince, we decided to go FME way to extract and insert/update/delete to DEFAULT version using changedetector + AttributeCreator transformers.
Thank you.
DerekLaw
Esri Esteemed Contributor
Hi @AbhijeetKulkarni,
I am trying to build replication between Oracle and MS-SQL geodatabases ...
FYI, this capability is available in ArcGIS, it's called geodatabase replication
Has anyone succeeded in building sync system where source and destination are ... different versioning  enabled?
I don't think this is possible. The purpose of replication is to "copy/transfer" content from one geodatabase to another; the same content. What you propose: 'converting' one method of versioning to another is not supported as far as I'm aware.
Hope this helps,
VinceAngelo
I've used a number of mechanisms to push contents from one database to another, but attempting this with different database vendors and such a large release gap and a different versioning model seems to drift into nightmare.  For a production system, you really need to limit to no more than one complication (and different versioning models should be scored as two or three complications).
Sorry.
- V
AbhijeetKulkarni
Thank you.
