Geodatabase lock
3998
09-11-2014 07:12 AM
BobBoutiette1
How do I remove a lock on a file geodatabase that I created?  I'm the only one that is using the gdb and I've closed everything down and reopened and I still get a failed to connect lock error.
JeffWard
Honored Contributor
There may be latent ArcMap or AcrCatalog processes running.  You can check using your task manager.  I have found rebooting usually clears the locks.
Jeff Ward
Summit County, Utah
