Geodatabase Enterprise
5147
7
09-17-2015 08:46 AM
DEVAPP
Hi guys,
i have a oracle database that contain all data with SDO_GEOMTRY.
And i see that with arcgis 10.3 i can connect this and works very well but i this way i'm working with native oracle format.
Instead if i have a ArcGIS Server i can create a geodatabase Enterprise on this oracle database.
I would like to know the difference or limitation if i works in native oracle format instead into geodatabase enterprise.
There is some link to see? Some Document?
Any help it's great
Thanks
QuinnFrancis
The link below provides some useful information on Oracle data types supported in ArcGIS
Oracle data types supported in ArcGIS—Help | ArcGIS for Desktop
DEVAPP
Thanks for your reply, but if i works with oracle data type without Geodatabase Enterprise i have some limitation about publish data? Example i can publish a feature service if my data it's on oracle and not into Geodatabase Enterprise? or i suppose that i can't use into map service the relation 1 to M if this relation is on oracle?
Thanks
by Anonymous User
Not applicable
I suppose you are using query layers for accessing third party spatial tables from ArcMap. If "yes", take a look at this post:
The Evolution of Query Layers | Support Services Blog
Regards
Jesús de Dego
DEVAPP
I'm using the Add Database connection
DEVAPP
Hi George,
thanks for your response.
Reading this links i see that my thoughts were right.
If my oracle it's not registered as Geodatabase Enterprise (Create Geodatabase Enterprise Geoprocessing tool) i can't publish feature service, i can't edit my data by arcmap but i can edit it by oracle, i can't use some relation 1 - m if is stored into oracle and so i can't use this into map service when i publish a mxd.
Right?
Thanks
AsrujitSengupta
You can publish data from a Database and use the ArcGIS Service to edit it
Publishing feature services from databases
Prior to 10.2, you could only publish a map service with feature access enabled (a feature service) to ArcGIS Server if the database contained a geodatabase. At 10.2, you can publish editable feature services from supported database management systems. See theArcGIS database management system requirements for a list of supported databases and spatial data types.
Beginning with ArcGIS 10.2, you should use ArcGIS Server feature services to publish data from a database rather than using ArcGIS Spatial Data Server feature services, as these have been deprecated.
What's new in ArcGIS 10.2 for Server:
http://resources.arcgis.com/EN/HELP/MAIN/10.2/index.html#//015400000640000000
