Field Name Length in Enterprise GDB (SQL Server)
4272
01-04-2016 11:02 PM
HaniDraidi
When I copy a feature class from file GDB to SQL Server enterprise GDB, some fields (their names contain more than 33 characters) are trimmed in the enterprise GDB.
What is the allowed field name length in enterprise GDB? Can I change it?
Thank you in advance,
Hani
JakeSkinner
Esri Esteemed Contributor
Hi Hani,
Unfortunately, field names are limited to 31 characters for SQL Server geodatabases:
Enterprise geodatabase size and name limits—Help | ArcGIS for Desktop
However, the field alias can be greater than 31 characters.
JakeSkinner
Hi Hani,
HaniDraidi
Many Thanks for the Clarification Jake
deleted-user-ZMHeMpwIlo8S
Has there been any development on this limitation?
JoshuaBixby
MVP Esteemed Contributor
There hasn't been, and I don't expect there will be for a while longer.  See the accepted answer on https://community.esri.com/thread/81043 for a bit more information.
