Features loaded into empty feature class using Object Loader disappear after saving edits.
1293
08-08-2017 07:18 AM
MeganJohnson
Using Object Loader in ArcMap to load features into existing, empty feature class (Esri Water Distribution Model - file geodatabase). Successfully load features and edit attributes, save edits, no errors, save and close Mxd. Reopen Mxd and feature class shows 0 of 0 records. Also shows 0 of 0 records when previewing in ArcCatalog. This has happened sometimes when the feature class is involved in a geometric network and also when it is not in a geometric network.
Running ArcGIS Desktop 10.4, with file geodatabases. Loading data from Enterprise geodatabase on SQL server
JakeSkinner
Esri Esteemed Contributor
Hi Megan,
Are you able to successfully append features to the feature class using the Append tool?
