failed to delete selected object(s) Must be the owner to perform this operation.
5066
06-10-2016 11:18 AM
RobinWilson2
George_Thompson
Esri Notable Contributor
Hi Robin,
You may want to move this to a different location that will give you a higher chance of a response like Geodatabase​ .
I am assuming based on your error message that you are using SQL Server for your geodatabase, correct?
Can you also provide the version of ArcGIS Desktop, version of SQL Server and version of the Geodatabase.
--- George T.
RobinWilson2
Yes, SQL server 2012, Enterprise SDE, 10.2.2, Desktop 10.3
George_Thompson
What system permissions do you have in SQL Server (sysadmin, etc.)?
It appears that SQL Server thinks that you are not the owner of the data. Is your user name and schema matching in SQL Server Management Studio?
--- George T.
RobinWilson2
It turns out that it was an old login-when I was using a laptop that I rarely use, it let me delete it there. Thanks for your help!
