Export Data option in ArcGIS Pro 3.4 not generating expected result
1379
11-19-2024 07:26 AM
AbigailMiller
Hi Everyone,
Recently I observed a strange behavior while working with ArcGIS Pro 3.4 that is whenever I try to export the feature class from file to enterprise geodatabase using the export data option (by right-clicking on the feature layer> data>export data in the table of contents) the feature of my data does not overlay on top of each other.
On the other hand, when I try the data migration using the copy-paste tool, export feature class to geodatabase tool, export XML workspace document tool, and copy features tool the features of my data overlay perfectly fine.  The data is sourced from a vendor.
Any help/opinions regarding the issue would be of great help!
Cheers,
Abigail
DanPatterson
MVP Esteemed Contributor
Export Features (Conversion)—ArcGIS Pro | Documentation
use the tool from arctoolbox and specify/check the output coordinate system in the Environments Tab of the tool.  The right-click method is a shortcut and doesn't have all the available options that the tool does
... sort of retired...
AbigailMiller
Thanks @DanPatterson . I will give it a try.
