Error in copying table from Enterprise GDB
3169
02-14-2016 11:00 PM
HaniDraidi
I have a table registered with an enterprise GDB, and I can open it and explore its records, when I copy this table to a file GDB, it starts copying but an error that says "a row with this OID already exists"
What might be the issue here?
Thank you in advance,
Hani
VinceAngelo
Esri Esteemed Contributor
It appears that a a duplicate row is the issue.  How is the TAX_FLAT_OWNERS_VIEW view structured?  Does it violate the rowid uniqueness constraint?
HaniDraidi
No, it was registered with the Geodatabase, and this should insure non-duplicates
VinceAngelo
And yet the error asserts otherwise.  View registration is a point-in-time validation process.  There's no way to be sure the view wasn't updated or the data in the viewed table wasn't changed to violate rowid integrity.
