Enable Enterprise GDB Failed
5613
08-11-2014 07:01 AM
SarahG
I am using ArcGIS 10.2 and SQL Server 2008 R2
I created a database in SQL Server Management Studio, then tried to Enable Enterprise Geodatabase in ArcCatalog but I get the following error message:
The geodatabase system table could not be created.GDB_Tables_Last_Modified : Error (-87)
See the setup log in the following location for additional error information:
C:\Users\mscadmin\AppData\Local\Temp\2\sde_setup.log
Could not create geodatabase schema.
Failed to execute (EnableEnterpriseGeodatabase).
Then the sde_setup.log says:
[Tue Aug 05 13:04:18 2014] Error creating  GDB_Tables_Last_Modified table...
[Tue Aug 05 13:04:18 2014] ERROR Creating Geodatabase tables
, Error = -511
,EXT_Error = 0
,EXT_ERROR1 = Invalid layer configuration keyword
,EXT_ERROR2 =
We have been using the same process to create geodatabases on this server for a while, and it was working fine up until a couple months ago.  Any help is appreciated.
rustemrustem
Hi Sarah. Could you solve this problem? If you solved you explain me pls.
BirajaNayak
If the issue still reproducible, then please log a support case with ESRI to troubleshoot the issue.
