Database connection error
2007
02-16-2024 08:22 AM
Abi
All effort to connect an existing Arcmap user to the database (sde) has proved futile. The user recently just changed his machine to a new one , and anytime I try to connect , I keep getting
"Unable to connect to database server to retrieve database list;please verify your server name and password info and try again"
How do I rectify this error message?
George_Thompson
Esri Notable Contributor
What version of ArcMap are you using?
What is the RDBMS and version being used?
Does ArcMap have the correct version of the client drivers installed?
--- George T.
Abi
ArcMap Version is 10.8.1.
RDMS - Microsoft SQL Version 2019
Version installed on driver is 10.8.1.
George_Thompson
Is the SQL Server running on a custom port?
Can you install SSMS on the ArcMap machine and make a connection with SQL Server?
What specific ODBC driver is installed: https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-sqlserver.htm#ESRI_SE...
Have you rebooted the machine since the install of the ODBC driver?
--- George T.
DavidPike
MVP Notable Contributor
Yes agree.  Error message seems like a red herring and is likely the driver.
Abi
Thank you All for your help. I was able to resolve it installing ssms and updatng the license type from standard advance.
