data source properties sde raster vs vector
4325
05-13-2016 02:15 PM
forestknutsen1
Why does the raster data source properties not show me me the authentication method?
DanPatterson_Retired
serviceProperties in Layer—Help | ArcGIS for Desktop has all kinds of cryptic stuff relating to sde... if it makes any sense to you, then that may be where your answer lies.
forestknutsen1
Thanks for the link Dan. I did look around in this location this morning.
Which is all good. I imagine that I could ask it with arcpy... But what I want to know is why does ArcCatalog not report this back to the end user?
interesting... you should run a quick arcpy test to see what it reports if anything at all
forestknutsen1
Sure
servProp = layer.serviceProperties
print "Authentication: " + servProp.get('AuthenticationMode', 'N/A')
Output: "Authentication: OSA"
So, that part does work. I also revoked permissions for the Oracle OSA reader role and the layer does in fact stop working, as one would hope. The behavior looks right.
you should send in a request as to why, perhaps, most don't care, but at least you have the workaround
